Philips 28PW6506/05 Picture compressed from sides
JohnM
PostPosted: Sun Sep 12, 2010 6:27 am    Post subject: Philips 28PW6506/05 Picture compressed from sides Reply with quote
Subject: Philips 28PW6506/05 Picture starts off compressed into vertical strip in centre of screen
Philips 28" TV
Model 28PW6506/05
Chassis CH 28RF PSLLR S10W 10P
On power up the picture is compressed into a vertical strip in the centre of the screen. This will expand outwards to the sides as it warms up. The picture may flicker as it stretches outwards and the set may shutdown. It can take 5 or 6 restarts to get it to hold centre at full size. Also, the picture is unstable on the right-handside and distorts when there is a very light area on the picture. The lefthand side is stable.
I have removed the case and can see no obvious damaged components.
The set has been retired to the garage before it fails completely but I would like to get it running again.
Any help you can give will be appreciated.
Thanks
PostPosted: Sun Sep 12, 2010 10:42 am    Post subject: Reply with quote
Possibly bad solder joints in the power supply or horizontal deflection areas.
PostPosted: Sun Sep 12, 2010 11:20 am    Post subject: Reply with quote
I think its probably more bad-capacitor related if it is gradually expanding outward.
JohnM
PostPosted: Sun Sep 12, 2010 12:44 pm    Post subject: Reply with quote
The problem started as a slow and steady deterioration. It didn't simply just appear. It does seem to be going downhill in a gradual if somewhat exponential way.
PostPosted: Sun Sep 12, 2010 2:44 pm    Post subject: Reply with quote
Oops.
PostPosted: Sun Sep 12, 2010 2:45 pm    Post subject: Reply with quote
O.K. You Win. Go ahead and name that tune...I mean capacitor. Smile
JohnM
PostPosted: Sun Sep 12, 2010 3:11 pm    Post subject: Reply with quote
For 10 points... can you name that capacitor?
(there are none that look all swollen or show any outward signs of problems)
PostPosted: Sun Sep 12, 2010 4:28 pm    Post subject: Reply with quote
something electrolytic near the HOT. Probably very close to the heat sink. I know that isn't as specific as you're hoping for, but it's as good as I can do.
terainlove
PostPosted: Sat Apr 30, 2011 9:50 am    Post subject: Reply with quote
Hi try replacing capacitor c2455 it's value is 47uf/35v
