Philips 30PW850H no picture red led 3 blinks
TvHatesMe
PostPosted: Thu May 13, 2010 6:54 am    Post subject: Philips 30PW850H no picture red led 3 blinks Reply with quote
Hi,
I've had this set for about 5-7 years and it's worked fine the entire time. About a week ago I turned it on and the led light on the front went green for about 15 seconds while i heard what sounded like the normal start up, then a series of clicks. The led then went red and will blink 3 times about every 5 seconds. I've read that this could be a problem with blown capacitors on the main board so I have the tv apart and have examined it all pretty closely but do not see any obviously blown components. I understand that at this point I would probably need to start testing individual pieces for issues. Does anyone have any suggestions as to maybe any common problems with these I should look into?
If it helps the TV has the EM1.2U AA chassis I believe.
Thanks.
