madrat27
Posted: Thu Oct 09, 2014 6:15 pm Post subject: PHILIPS 32pf4320/10 LCD screen turns green, menu keeps color |
Hey,
I'm trying to fix my tv, but could use a bit of advice .
PHILIPS
32pf4320/10
prodnr. qg 1a0526 061403
I have a philips LCD tv screen. Last week the color of my screen changed. It only can show green colors. It is not a problem with the cable, because when I plug my pc in with a vga-cable the screen also turns green. What I find really strange is that the menu for changing channels or adjusting brightness hasn't lost its color. It is still the normal blue menu (not in green).
https://drive.google.com/folderview?id=0B8PE0BKHDCGyNHo2Q1VpSUtURG8&usp=sharing
My plan is to change the mainboard, hopefully that will fix my problem. The mainboard productcode is: 1293 12301 00388 d2521 hj525.
So my question is basically, is this a good fix? Or can I do it cheaper? Did I miss a simpler solution?
thank you! |
Posted: Sat Oct 18, 2014 9:26 am Post subject: |
Don't forget that the set has a tcon and inverter board under metal chassis.
I'd remove, clean (any that can be cleaned) and reseat all tcon ffc connectors first. |
madrat27
Posted: Wed Oct 22, 2014 6:55 am Post subject: |
Wauw, thank you I'll do that first. I'll post when it is done. Thanks!! |
