Philips 32PT6441/37 shuts down
_Tony
PostPosted: Tue Mar 10, 2009 10:47 am    Post subject: Philips 32PT6441/37 shuts down Reply with quote
Philips 32pt6441/37 chassis L04.1UAA the customer says it shuts down after
an hour or two and the light blinks. The TV just came into the shop and I
have a call for the same model and the same problem Monday. Any help would be appreciated.
_Eric
PostPosted: Tue Mar 10, 2009 10:48 am    Post subject: Reply with quote
I'm not sure if it's your problem, but there is a Horizontal Drive Kit for
that chassis.
Replaced The Horizontal Drive Kit Part # 483531057673.
_Tony
Update light blinks 3 times then pause then 2 times you may be wright about
that kit it gets bright flash in the center of the screen a couple of times
before it goes out I will look at the drive transformer to see if its been
hot.
_Jim
Hi,replace capacitor location #2455, good luck
