Philips 42PF5321D/37 No Picture, Red LED Flashes
_JOshD
PostPosted: Sun Sep 20, 2009 5:59 am    Post subject: Philips 42PF5321D/37 No Picture, Red LED Flashes Reply with quote
Working on a Philips 42PF5321D/37 42" plasma. When plugged in, the green front panel LED comes on for 3-4seconds while several relays click. After 5 seconds, the unit goes into a stand by processor fault mode. The red LED blinks 6 times, waits a few seconds, then repeats. I have the service manual, which seems to suggest the 5V supply for this fault, but am having trouble tracking down anything obvious. I have the power supply board out and there are no obviously blown caps, etc. Can anyone suggest anything to check?
_daveG
PostPosted: Sun Sep 20, 2009 6:00 am    Post subject: Reply with quote
Check: C8059,C8060 ON P/S,3300@10.
_JaseVan
PostPosted: Sun Sep 20, 2009 6:01 am    Post subject: Reply with quote
I found 6 blinks is the signal processor:
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
