Philips 42PF94310/378 vertical line
c9h9no3
PostPosted: Thu Mar 24, 2011 7:29 am    Post subject: Philips 42PF94310/378 vertical line Reply with quote
I have a Philips Flat TV - HDTV model number 42PF94310/378 My problem is, now when I turn in on there is approximately 3-4" black vertical line going up the screen (near the center of the screen). I'm decent with fixing technical problems on computers etc, but I don't really know much with televisions and what could be causing this problem. Should I take it in for repair, or is there something i can replace fairly easily?
Thanks for your help!
c9h9no3
PostPosted: Fri Mar 25, 2011 2:24 pm    Post subject: Reply with quote
Here is a image of the problem im describing.
http://tinyurl.com/6gravdl
KMpuggy
PostPosted: Sun Mar 27, 2011 8:13 am    Post subject: Reply with quote
That looks like something to do with a buffer board. Maybe that certain part of the board has had it, or ribbon failure or loose connection.
c9h9no3
PostPosted: Sun Mar 27, 2011 8:16 am    Post subject: Reply with quote
Do you know how I would identify the failing buffer board?
KMpuggy
PostPosted: Sun Mar 27, 2011 8:39 am    Post subject: Reply with quote
Im the same as you, more into PC repair, not really touched tellys but im here because im also having problems. Very Happy
Have a watch of this, might give you some idea about the fault finding.
http://www.youtube.com/watch?v=5hVi5gd0aec
With my telly ive got a buffer board on the side, and one on the bottom, some have them on the top and bottom etc. They are a long strip like board with ribbons connected to it, it will be something to do with the connection/board directly where the line is on your screen.
c9h9no3
PostPosted: Mon Mar 28, 2011 5:38 am    Post subject: Reply with quote
Amazing video, cant wait to jump into this. Thanks!
c9h9no3
PostPosted: Mon Mar 28, 2011 6:46 am    Post subject: Reply with quote
Alright, Im 90% sure Ive found the problem and a new board would not be the solution.
While removing the ribbon that coorilated to the black bar on the screen I found that some of the wires within the ribbon have become exposed and broken causing the short. Now the bad thing is it looks like the other side of this ribbon is connected to the panel itself. Any know how there would be a way to repair?
I included some images, sorry if the quality is poor.
Particular bad ribbon
http://tinyurl.com/66smr9q
Close shot of broken and exposed wire
http://tinyurl.com/45sjtx7
Any advice would be great. Thanks!
EDIT:
For the close shot, if you look to the right of where my finger is pointing, you can somewhat see the thick black line on the ribbon running up and diagonal. In the middle or so the wire starts to extrude out of that black line. Really hard to see on this close of a shot.
KMpuggy
PostPosted: Mon Mar 28, 2011 7:50 am    Post subject: Reply with quote
Not good news i dont think. Most flat screen tellys are like you said, with the ribbon built into the panel. So you cant just replace them, its either a new panel which is costly, or the only other thing is try and repair/bodge the ribbon.
c9h9no3
PostPosted: Mon Mar 28, 2011 8:23 am    Post subject: Reply with quote
I really dont think that the ribbon is recoverable. Do you know a way to repair/bodge/mickey mouse the ribbon?
c9h9no3
PostPosted: Mon Mar 28, 2011 8:56 am    Post subject: Reply with quote
Not to ask to many questions, any idea where i should look for fair priced replacement panels for this television?
EDIT
I found the panel, it looks to be approx 160$.
