Philips 60PP9352-17
chris1123
PostPosted: Mon Oct 20, 2008 9:16 pm    Post subject: Philips 60PP9352-17 Reply with quote
The first problem was the tv would come on but the colors were seperated. I figured it was a converence issue and replaced both converence ics. I checked the resisters and found all too be good. Now the second problem is I re-installed the converence board and hooked everything back up. Now when I turn the tv on, it comes on for a couple of seconds and turns off. No picture or sound. Does anyone know what might be the problem???
PostPosted: Tue Oct 21, 2008 11:19 am    Post subject: Reply with quote
I would suggest removing the convergence board again and USING A MAGNIFYING GLASS. examining the soldering on the convergence IC's. This is not a test of you soldering abilities, bridges between solder points can be very small and is a VERY common thing to find when IC's are replaced.
Hope this helps.
chris1123
PostPosted: Tue Oct 21, 2008 1:37 pm    Post subject: Reply with quote
Thanks Jesse for your reply!! I will try that when I get a change to work on it again! I will keep you updated...
