Philips Magnavox 60PP902 - Should I continue?
aaronbaird1
PostPosted: Fri Feb 04, 2011 9:46 pm    Post subject: Philips Magnavox 60PP902 - Should I continue? Reply with quote
I have acquired an old 60" HD RPTV that was in serious need of a coolant change. Following the guide from this website I have made it as far as cleaning out the old coolant in the first CRT (blue I think). But I noticed it looked different from the picture in the guide. As you can see, there is a brown tinted square on the inside of the CRT. This picture is after i cleaned the chamber. Again, this is BEHIND the glass that I cleaned inside the chamber.
From the Guide:
So, should I go any further? I'm worried that after putting in new coolant and re-installing it, I still wont have a decent picture. Also, is there anyway to open the CRT and clean it from the inside?
Thanks for your replies,
Aaron
PostPosted: Sat Feb 05, 2011 8:48 am    Post subject: Reply with quote
Those CRTs are going to have some burn in no matter what... because they have been used. I suspect your image will still be much better than it was before you changed the coolant.
The only way to open the actual CRT itself is to have a clean room, and a giant vacuum pump, along with a bunch of other tools I don't remember. I also remember something about hazardous chemicals needed to do it. I read an article once about a place that repaired antique CRTs with a pretty sweet custom setup. But that is way outside of your (and my) league, as well as extremely cost prohibitive.
PostPosted: Sat Feb 05, 2011 10:35 am    Post subject: Reply with quote
Can't you use a Shopvac? Laughing
