Philips Magnavox MS2530 C225
PariahComplex
PostPosted: Mon Oct 12, 2009 11:53 am    Post subject: Philips Magnavox MS2530 C225 Reply with quote
This is my last effort before I push the tv out the window it sits in front of. I'm an avid video gamer and in one room have an HD set up with surround sound and the works but one game (rock band) keeps the downstairs neighbor awake with the drumming so out of courtesy I unhooked my xbox 360 from the HD and Surround setup and brought out to the SD in the front room. This is the original TV I always played it on before I upgraded to HD, hooked it up with the right cables (yes the tech support kept asking over and over, I used the yellow, red, and white in the right plugs, I know what i was doing), but when I turned it on it was black and white. Tried bypassing the junction box and hooking straight to the tv, same problem. Tried other gaming systems on the tv, all in color. Tried the xbox on another SD tv, worked perfectly fine. Even bought new cables. No luck. Tried going into the service menu and I can't navigate it with the buttons on the tv or the controller buttons they all change the channels or the volume and won't let me control the service menu, all I want to do is factory reset the TV. I read somewhere to unplug for four hours, plug it in power it on, turn it off, and repeat for a double hard reset and it would work but all my programmed setting were still there. Called Magnavox but since the TV is over a year old they won't help me, and of course since it's a problem with the TV no help from XBox support. So all I need is a way to reset my TV back to it's factory defaults, any help would be greatly appreciated, thanks in advance, or if you've heard of this problem and know a fix that would be great as well.
PostPosted: Mon Oct 12, 2009 11:56 am    Post subject: Reply with quote
if your xbox has a setting to change from 480i to 480P... make sure it is set to 480i
PariahComplex
PostPosted: Mon Oct 12, 2009 12:15 pm    Post subject: Reply with quote
unfortunately there's no way to change it when it's set in SD mode, in HD mode you can change it only to 420p, 720p, 1080i, 1080p
PostPosted: Mon Oct 12, 2009 1:28 pm    Post subject: Reply with quote
Sounds like you may have hooked up your composite cable's (Yellow,White,Red) to the component input of the tv (this will produce B&W pix) .
PariahComplex
PostPosted: Mon Oct 12, 2009 3:33 pm    Post subject: Reply with quote
it's an older tv it only has hookups for composite and coaxial, not too old, probably like '99, '00, this is why I'm so confused
