Philips Magnavox Guest
Posted: Thu Jul 19, 2007 5:42 am Post subject: Philips Magnavox Service Menu Codes - Plasma, LCD, CRT, RPTV |
# Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
# Turn the TV off to exit the Service Menu. |
Posted: Thu Jul 19, 2007 5:42 am Post subject: Service Code |
* Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
* Turn the TV off to exit the Service Menu. |
Posted: Thu Jul 19, 2007 5:43 am Post subject: Service Code |
* Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
or
* Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
* Turn the TV Off to exit the Service Menu. |
Posted: Thu Jul 19, 2007 5:44 am Post subject: Service Code |
* Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
or
* Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
Mangavox Philips Guest
Posted: Sat Jul 21, 2007 2:08 am Post subject: Service Menu Key Sequence |
* With the TV off:
Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
To Factory Mode:
Step 1 : Select the source "PC" and then turn off LCD-TV.
Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
Press "menu"button and bring up factory mode indication |
