ElectroTech
Posted: Fri Aug 07, 2009 8:43 am Post subject: Philips Model 27PT5441/37 shuts off |
I have the above mentioned tv. It turns on, but after a while it shuts off by itself. Sometimes it takes 5 minutes and sometimes 2 hours before it turns off. The green light on the front blinks in the following pattern : 1-5-2-11. Then it repeats itself with the same pattern. Can someone help. |
Redhishan
Posted: Sat Aug 08, 2009 9:57 am Post subject: |
Is the picture on the screen fluctuating?
If yes, try decreasing the screen on the horizontal transformer and see if the TV shuts down. Probably the protection is being activated due to high screen on the CRT, or the horizontal transformer is defective. |
ElectroTech
Posted: Sat Aug 08, 2009 5:01 pm Post subject: Philips 27pt5441/37 |
I will try that and see what happens. Thank you for that suggestion |
ElectroTech
Posted: Mon Aug 10, 2009 3:46 pm Post subject: |
I am sorry but that remedy did not work. Do you have any further suggestions? |
Posted: Mon Aug 10, 2009 6:55 pm Post subject: |
Try a horizontal driver kit, 483531057673. |
