Philips Plasma 42PF9630A vertical lines
_Al
PostPosted: Wed Aug 19, 2009 11:15 am    Post subject: Philips Plasma 42PF9630A vertical lines Reply with quote
The complaint is colored vertical lines on top of picture. Haven't seen this yet am trying to help another tech. Says you can see the picture behind the lines.Checked all my tips and tech assist tips. I haven't had a Plasma here yet. Have a manual. Has anyone run into this yet?
_Shane
PostPosted: Wed Aug 19, 2009 11:15 am    Post subject: Reply with quote
I would suspect the logic module. but I had problem with other brands other
than phillips. I would even check all the connectors on the c module it it
only in sections around the perimeter of the set.
but likely a logic module.
some call it the digital module.
rrobor
PostPosted: Sun Aug 23, 2009 5:08 am    Post subject: Reply with quote
Pholips dont make a Plasma TV, that is a rebadged LG and the usual is 2 or 3 panels faulty
