Phillips 47PFL5432D/37 - wont power on, 6-3 blink error code
asdflkj
PostPosted: Tue Jul 26, 2016 5:13 pm    Post subject: Phillips 47PFL5432D/37 - wont power on, 6-3 blink error code Reply with quote
Powers on, nothing shows on screen, a few seconds later powers off and the LED flashes 6 times (long) and then 3 times (short). It had 4 blown capacitors, 2 each on boards labeled master and slave. I just replaced the cap's, and it does the exact same thing.
curtis wolfe
PostPosted: Fri Jul 29, 2016 12:37 pm    Post subject: Reply with quote
THIS INDICATES THAT THE POWER OK DETECT FAILED TO GO HI 3.2 VOLTS ON CONNECTOR IP11 PIN 2 ON THE LARGE POWER PCB. MY SET HAD A LEAKY KIA431L OVERVOLTAGE MONITOR Z401. OUT OF CIRCUIT IT MEASURED 18K OHMS LEAKAGE ON 2 OF THE PINS AND A NEW ONE READS 4MEG ON ALL 3
