Phillips 55PW936317F Coolant replacement question
riven67
PostPosted: Wed May 26, 2010 8:28 pm    Post subject: Phillips 55PW936317F Coolant replacement question Reply with quote
I know I have to replace the coolant as I have the classic symptoms and I have read the guide, but it does not mention if you have to discharge the crts. I am a newbie to television repair but I thought any tv with any sort of picture tube had to be discharged before working on it. Does this not apply to projection tv's?
PostPosted: Thu May 27, 2010 6:59 am    Post subject: Reply with quote
When in doubt... Discharge it.
PostPosted: Thu May 27, 2010 11:29 am    Post subject: Reply with quote
Caution, The normal discharge method for these kind's of crt's can cause arcing after the fact, (After you have completed the repairs and turn the set on), as they are installed with a silicone based dielectric sealant compound. DO NOT insert any instrument under the cap as it will damage the dielectric properties of the anode cap you are working on. The simplest method is to touch the second anode wire to chassis ground after removing it from the IHVT. Do not attempt to remove the second anode cap directly from the CRT or insert any instrument under the cap.
riven67
PostPosted: Fri May 28, 2010 2:59 pm    Post subject: Thanks for the info Reply with quote
Thanks for the info. I will take this advice when I decide to do the coolant replacement.
