Playstation3 YLOD repair and Silicon termal Compound Past
ivtec
PostPosted: Thu Dec 12, 2013 10:48 am    Post subject: Playstation3 YLOD repair and Silicon termal Compound Past Reply with quote
Hi guys: have here an Old Play station3 that when powering up it goes green for a second and the fan also turns on for a second then shuts off with red led blinking,
http://www.youtube.com/watch?v=J5fzUrP0pxs
i have it dissembled so i want to try to do the YLOD repair,
i only have AK-100 Silicone paste can i use it for this or should i buy other type?
Davy
PostPosted: Fri Dec 13, 2013 10:45 am    Post subject: Reply with quote
Yes the paste should be OK.
You need to ensure that both surfaces are spotless and try avoid scratching them, then apply a thin smear to one surface only.
Why use heat sink paste?
If you look at the surfaces under a microscope it will look a bit like the moons surface - all cratered, obviously where these uneven surfaces are there will be no metal to metal contact, there will just be an empty void.
What thermal paste does is to fill these craters in, the heat will then flow through the paste particles rather than across an empty hole.
It can be said that using no paste at all is far, far better than piling it on as though we were greasing a gear box.... the secret is just to use a smear, use too much and we make the heat transfer worse.
I used the moon for want of an easy explanation - obviously the surfaces isn't that bad, but you can see what we are trying to do.
Dave
