joealbert7
Posted: Sun Mar 21, 2010 7:31 pm Post subject: PN50A450 SAMSUNG ADC CALIBRATION PROBLEM |
BY MISTAKE I ENTERED IN THE SERVICE MENU OF MY SAMSUNG PLASMA PN50A450. IT CAN NOT GET CALIBRATED IN AV, PC AND HDMI. ANYONE HAD THIS PROBLEM BEFORE? I NEED TO SOLVE THIS MISTAKE BY GETTING IT CALIBRATED. THANKS |
Posted: Sun Mar 21, 2010 8:39 pm Post subject: |
WHAT? |
Posted: Mon Mar 22, 2010 2:00 am Post subject: |
Send it back to Korea on the next boat.
They may still have the equipment and jigs available to align it back.
What will it take to convince laypeople: "If it does this when you do that ... don't do that."
If you don't know the following BEFORE you press the first button - DON'T press the first button!
1) How to enter into the service menu;
2) What adjustment do I want and what effect should adjustment cause;
3) How to "save" (or not) any adjustments; and
4) How to properly exit the service menu. |
Posted: Mon Mar 22, 2010 11:35 am Post subject: |
What you are saying is not making sense. (no offence) There are many, many, many points of alignment in the service menu. (calibration is a nonsensical word used by know-it-alls that think they can do a better job of alignment than the factory).
If you can tell me exactly (and I do mean exactly) what you have changed, I can give you the default values for these points.
Hope this helps.
joealbert7
Posted: Sun Mar 28, 2010 7:53 pm Post subject: PN50A450 SAMSUNG PLASMA |
Jesse Mack wrote: | What you are saying is not making sense. (no offence) There are many, many, many points of alignment in the service menu. (calibration is a nonsensical word used by know-it-alls that think they can do a better job of alignment than the factory).
Hope this helps.
Jesse | IF YOU PRESS "MUTE", "182" AND "POWER" IT DIRECTS YOU TO SERVICE MENU. THEN IF YOU GO DOWN TO AND SELECT "ADC" THEN YOU'LL SEE A LITTLE WINDOW ON THE UPPER LEFT CORNER WHERE YOU CAN SEE 4 SELECTIONS: AV, COMPONENT CALIBRATION, PC, HDMI. IF YOU SELECT AND PRESS ENTER ON ANYONE OF THOSE YOU'LL SEE THE WORD "WAITING" INSTEAD OF "SUCCESSFULL'. IT KEEPS ETERNALLY ON THIS WORD (WAITING).[/quote] |
Posted: Tue Mar 30, 2010 12:00 pm Post subject: |
This is a good example of the problems you can run into by trying to do something you are not familier with or do not understand. Entering into any SERVICE MENU should not be done if the SERVICER does not understand the terminology so the SERVICER can stay out of trouble.
This goes for ANYONE who reads this.
You have entered into an area that REQUIRES test equipment.
What you entered into is the autoadjustments that require generator inputs of specific patterns to the specific input mode being adjusted. For a more complete explaination of what I am talking about go here:
http://www.scribd.com/doc/2928513/Samsung-PL42P7HPX-TV-Plasma-Display
Please allow sufficient time for the information to load.
I know it is not your exact model but the directions are the same.
I would suggest taking the unit to a WARRANTY AUTHORIZED SERVICER to have the unit repaired.
Jesse Please take note the statement.
