Thisisbuod
Posted: Tue Jun 14, 2016 4:04 pm Post subject: Polaroid tda03211c - no video |
I have a Polaroid tda03211c. When I hit the power button the led changes to blue and I can hear the dvd player turn on, but I have no picture at all. I replaced all the capacitors on the power board (cause I noticed a few swollen ones). Screen is still just black. I checked all the connections inside and they all seem fine. I shined a flashlight on the screen and didn't see anything so I'm assuming it isn't a Backlight issue. Can anyone point me in the right direction to properly diagnose this issue? |
Posted: Tue Jun 14, 2016 4:53 pm Post subject: |
Check D10; EC17 & EC18 |
Thisisbuod
Posted: Tue Jun 14, 2016 9:07 pm Post subject: |
Ec 17 and 18 are good. I'm getting a .4 voltage drop at that diode, but it's still attached to the board. It says in my (Multimeter) manual that it should be between .5 and .8 Do you think it's bad? |
Posted: Tue Jun 14, 2016 9:24 pm Post subject: |
Disconnect (float) one side and retest. |
Thisisbuod
Posted: Tue Jun 14, 2016 9:46 pm Post subject: |
I pulled it off. The first time I checked it it started at .550 and kept climbing. The second time I checked it it stayed around .681 and didn't really change. |
Posted: Wed Jun 15, 2016 1:43 am Post subject: |
Which Power Supply? According to SJ there were three possible used in that model. |
Thisisbuod
Posted: Wed Jun 15, 2016 7:44 am Post subject: |
It looks like it's a tc18813f. I couldn't figure out how to post a photo. |
Thisisbuod
Posted: Wed Jun 15, 2016 8:49 am Post subject: |
I tested that diode (uninstalled) and it read .4. I'm going replace it cause it doesn't seem to be acting the way it should. I read somewhere that the Mur420 is a good upgrade to the stock Her303. Is this true or should I just stick to the original equipment? |
Posted: Wed Jun 15, 2016 9:11 am Post subject: |
With meter on Diode test, over-range with one polarity of test leads - .4 in the other, sounds just fine to me.
Part number can be found on a sticker.
SJ has pictures |
Thisisbuod
Posted: Wed Jun 15, 2016 11:46 am Post subject: |
So, if the diode and those capacitors are good, what should I look at next? |
