Prima PH4237P 42" Plasma Power Supply Blinking Red LED
hawkeye
PostPosted: Sun Dec 05, 2010 10:21 am    Post subject: Prima PH4237P 42" Plasma Power Supply Blinking Red LED Reply with quote
Hello to all, and many, many thanks in adavance for all youor help!!!
A customer came to me with the television in my subject header, with exactly the same symptoms described in this forum:
http://forum.electromaniacs.com/topic/5102-prima-ph4237p-42-plasma-power-supply/
I changed all the necessary components, except for the STR-F6467, which I could not locate, so I replaced that with an STR-F6167, hoping that would be alright.
In any event, the TV passed the "smoke test", in other owrds, nothing exloded thankfully when I turned it on....but the problem is it does not stay on!
I'm getting no voltages out to either the cathode or anode board of the plasma screen, and there is a blinking red LED on the power supply itself.
In any event, the television does not turn on. Power LED goes from standby red to "on" blue for a few seconds, then shuts off, and then LED on power supply starts its blink cycle.
Any help would be greatly appreciated. I checked the main caps on the power suppply (ohmeter test), and they seem to ok (resistance builds).
Any help would be much appreciated.
