problem with tv RCA model #F19430
Mario
PostPosted: Sat Jul 05, 2008 6:20 am    Post subject: problem with tv RCA model #F19430 Reply with quote
This tv has some weird problems. Tv will power up but it wont stay on one channel it just keep running scanning all the channels. sometimes i wil press the menu button and it would cut off, other times i would press the volume button and it power on/off. I have seen retrace lines comming on and off after which it would go off.
I am getting B+, also the 25 volts and the 200v. up to the crt. board. i have change some caps around the vertical l/c eventhough i am getting the 25 volts out.
Dont have a schem. any tips would do.
Don
PostPosted: Sat Jul 05, 2008 6:22 am    Post subject: Reply with quote
Replace all of the front panel swithches. Sounds like they have been
contaminated
Calvin
PostPosted: Sat Jul 05, 2008 6:23 am    Post subject: Reply with quote
Have had RCA's in past with resistance in pushbotton switchs. Suggest removing one at a time and check using remote. One of the units had three bad and caused intermittent problems until replaced.
Terry
PostPosted: Sat Jul 05, 2008 6:24 am    Post subject: Reply with quote
Mario, it sounds like the "windex syndrome". Remove all the switches and try
the remote. my bet is also contaminated tact switches / switches.
Mario
PostPosted: Sat Jul 05, 2008 6:25 am    Post subject: Reply with quote
Got a fix. Problem was eeprom 24c04p. i replaced the eeprom and back to normal.
Thanks to all those who assisted me with tips.
Mario
