Projection Tv HV Anode Cap
Rockstar
PostPosted: Fri Nov 14, 2008 4:42 pm    Post subject: Projection Tv HV Anode Cap Reply with quote
On the blue crt, it pops sparks out of the hole the wire goes into on the HV Anode cap, the green crt had the same problem so i replaced the cap but i was wonder is there a reason its doing it cause some times it dont pop but when it does pop mybe after 20 minutes it wont pop no more. So is there any way to fix it or is it just going bad the HV Anode Cap, and is there any site to buy then from.
