Proscan plded4616 - lines on screen - pictures
ocf
PostPosted: Fri Jul 15, 2016 11:49 am    Post subject: Proscan plded4616 - lines on screen - pictures Reply with quote
Hello all, great community here, very thankful for the support and advice, been a lurker up until now.
Issue I am experiencing is with a 46" Proscan TV, it turns on, shows the proscan splash screen then powers off and back on again to the splash screen. Stuck in this loop.
No obvious issues with mainboard, I did very little in the way of diagnosing the problem. I bought a replacement board of ebay, after fitting it the TV now powers on and gets past the splash screen.
The issue now is that white areas of the screen appear to have lines going through them, this also affects the Proscreen splash screen logo which is white, this was not happening with the old board, the logo appeared ok and smooth.
If it helps shapes also appear jagged and edges of things are not smooth, difficult to describe really.
I hooked up VGA from a PC and this source was also affected with the white problem, this issue also affects the TV settings menu.
Any suggestions? I still have the old board, tempted to swap it back to see if the Proscan logo displays ok again just to make sure I didn't damage anything else when putting the TV back together.
Images of problem -
https://postimg.org/image/g4xj7uhwn/
https://postimg.org/image/j0ameplwn/
https://postimg.org/image/wv8wx6gbr/
https://postimg.org/image/osaqluvqf/
Any help greatly appreciated!
