Prosonic 36" Horizontal line
leichler1
PostPosted: Thu Oct 08, 2009 8:43 pm    Post subject: Prosonic 36" Horizontal line Reply with quote
Proscan RCA 36"
Manufactured by Thomson Consumer Electronics Model PS36123
36 Diagonal
older unit at least 8 years old
The problem is that the picture shrinks down to a horizontal line across the center of the screen.If I tap the TV hard the picture will come back on for a while
I have heard that this generation or model was known for bad soldering.
Where might the component be located?And what component do you think it may be?
PostPosted: Thu Oct 08, 2009 11:18 pm    Post subject: Reply with quote
resolder the vertical IC. if that doesnt work, replace the capacitors in the vertical circuit.
What chassis number is this?
PostPosted: Thu Oct 08, 2009 11:22 pm    Post subject: Reply with quote
Prosonic. Is that similar to a Magnasonysonicsung? Laughing
Resolder the vertical output I.C. pins.\
Yes, I know yours is different...
http://www.riddledtv.com/repair/journal/Vertical/
Edit: That would be a CTC169EJ5
