dblkc
Posted: Wed Jul 21, 2010 7:19 pm Post subject: RCA 20F424T |
When you press a button on the front other than power (menu, channel) the power goes out you have to press that button to bring the power back on. The power button will not bring the power back on????? |
Posted: Wed Jul 21, 2010 7:37 pm Post subject: |
Buttons/switches have been known to become defective. |
dblkc
Posted: Wed Jul 21, 2010 7:51 pm Post subject: |
both menu and channel???? |
Posted: Wed Jul 21, 2010 7:59 pm Post subject: |
If you're gonna do it, do it right. Change ALL OF THEM. |
dblkc
Posted: Fri Jul 23, 2010 5:44 pm Post subject: |
just found out from my dad that the remote causes the same thing to happen, also the TV will turn itself off and on. |
Posted: Fri Jul 23, 2010 5:54 pm Post subject: |
If you have isolated all the switches, any one which could be sticky/oxidized, then you might be able to say the remote is causing the same thing. Only other things I can recall causing were a bad EEPROM and bad solder joint(s). |
