RCA 27" CTC158/159
twintom
PostPosted: Mon May 05, 2008 5:53 pm    Post subject: RCA 27" CTC158/159 Reply with quote
Picked up a S.E.T. (Somebody Elses Trash) yesterday. Sign on screen said "Works Great - FREE". Sure enough brought it home, plugged it up and worked great, as advertised. Played for about an hour then turned off. Today, wife went to turn it on and only thing we're getting is a recurring "tick" about every six seconds or so. Is this indicative of a faulty flyback transformer? Opened it up and no obvious problems seen - ticking appears to be coming from the flyback transformer. No fried components or questionable solder joints. Any advice would be greatly appreciated. Unit is for mother-in-law visits (cheap is good!)
Pictures:
http://www.riddledtv.com/forums/images/userposts/t778/Picture001.jpg
http://www.riddledtv.com/forums/images/userposts/t778/Picture002.jpg
Video:
http://www.riddledtv.com/forums/images/userposts/t778/Picture.mov
PostPosted: Tue May 06, 2008 6:34 am    Post subject: Reply with quote
you probably have a capacitor that has dried up and changed value.
I'd test the HOT first though.
SET is a good one, I usually refer to it as Large Item Pickup. They have a special day once a year where everyone sets out large items that wont fit in their trash can. The city hauls them off for free on that day. Or someone else does.
PostPosted: Tue May 06, 2008 10:53 am    Post subject: Reply with quote
found a troubleshooting guide:
Here
twintom
PostPosted: Tue May 06, 2008 2:57 pm    Post subject: Reply with quote
Thanks for the quick reply. I need a little guidance to troubleshoot per your advice - what does HOT refer to? Is this the sequence detailed in the guide you provided?
twintom
PostPosted: Sat May 10, 2008 5:30 pm    Post subject: Reply with quote
Please help. I visited a site (tech-tips page, I believe)that described my symptoms exactly. Site advised replace Q4103. Have removed Q4103 from chassis, but need to know what to shop for to replace. Markings are
925I
30613
E B C
I know what the E B C is but cannot cross-reference a replacement from the other identification. I have an assortment of Radio Shack NPN and PNP transistors but have no idea which to choose.
twintom
PostPosted: Sun May 11, 2008 9:29 am    Post subject: Reply with quote
Q4103 tested OK so I reinstalled. I have two photos and a short video of symptoms in action, but do not know how to post them. If someone can help, I'll post them and hopefully, with an experienced eye, make some progress. :?
PostPosted: Sun May 11, 2008 12:57 pm    Post subject: Reply with quote
HOT is the horizontal output transistor. I dont know what number that is on your board. Ive actually never worked on a ctc159, those are quite old now.
Were you able to try the troubleshooting chart that I attached?
silv
PostPosted: Sun May 11, 2008 1:30 pm    Post subject: Re: RCA 27" CTC158/159 Reply with quote
Here is lots of tips hope these help.
Harry
RCA CTC159
Wed Dec 24, 2003 12:16PM
24.235.162.109
RCA
F27170
CTC159
CHIRPING OR SQUEALING FROM POWER SUPPLY-PIX HAS WIGGLES OR SMALL HORZ. TEARING.
CHECK/REPLACE C4171 FOR BROKEN
RCA
F27170
CTC159
REDUCED VERTICAL AND HORIZONTAL DEFLECTION
CHECK/REPLACE Q4101 AND Q4102 (MAY CHECK OK OUT OF SET)
RCA
F27170
CTC159
RETRACE LINES
CHECK/REPLACE Q2901 FOR LEAKAGE
RCA
F27170
CTC159
VERY DIM PICTURE
CHECK/REPLACE R2701 FOR OPEN
RCA
F27170
CTC159
POWER TURNS ON/OFF CONTINUOUSLY - SET WILL RUN AT 80 V AC
CHECK/REPLACE CR4160 IF 5V SUPPLY IS OVER 5 VOLTS
RCA
F27171
CTC159
NO HORIZONTAL SYNC
CHECK/REPLACE CR4120 AND C4171 (SMD)
RCA
F27171
CTC159
NO AUTO-PROGRAMMING AND RANDOM ACCESS SLOW
CHECK/REPLACE C3302 FOR LEAKAGE
RCA
F27171
CTC159
NO PICTURE OR SOUND AND SET PULSES ON/OFF
CHECK/REPLACE CR4164 FOR LEAKY OR CHANGE IN VALUE
RCA
F27171
CTC159
INTERMITTENTLY SHUTS OFF - PIX MAY PULL IN ON THE SIDES
CHECK/REPLACE R117 (B+ CONTROL) OR CONNECTIONS ON THE B+ POT. ITSELF
RCA
F27171
CTC159
INTERMITTENTLY HORZ. GOES WAY OFF FREQUENCY - SQUEALS AND HEATS UP HORZ. OUTPUT - SHORTS HORZ. OUT. IF LEFT ON
CHECK/REPLACE Q4301 HORZ. DRIVER XSTR.
RCA
F27171
CTC159
RIGHT SIDE OF SCREEN PULLED IN ABOUT 1'
CHECK/REPLACE CR4120 (MAY CHECK GOOD)
RCA
F27171
CTC159
SCREEN LOOKS AS IF SET HAS PURITY PROBLEMS BUT DOESN'T SHOW UP ON A B-W SIGNAL.
CHECK/REPLACE C2804 (SMD)
RCA
F27171
CTC159
NO OR INTERMITTENT VERTICAL SWEEP
CHECK/REPLACE C4505 OR CONNECTIONS
RCA
F27171
CTC159
VIDEO FLASHES AND GETS WASHED OUT AT TIMES
CHECK/REPLACE C2720 (SMD)
RCA
F27171
CTC159
RETRACE LINES
RCA
F27171
CTC159
NO PICTURE AND NO SOUND - POWER SUPPLY CYCLES ON/OFF ABOUT ONCE EVERY SECOND
CHECK/REPLACE R4109
RCA
F27171
CTC159
RCA
F27171
CTC159
NO VIDEO
CHECK/REPLACE R1435
RCA
F27171
CTC159
RCA
F27171
CTC159
WILL NOT TUNE OR AUTOPROGRAM - MANUALLY SCANNING THROUGH CHANNELS LOOKS LIKE AFT OR TUNING PROBLEM.
CHECK/REPLACE IC U1001
RCA
F27171
CTC159
DEAD SET
CHECK/REPLACE Q4301 AND R4101
RCA
F27171
CTC159
DEAD SET BUT DOES MAKE A TICKING SOUND
CHECK/REPLACE Q4103
RCA
F27171
CTC159
RCA
F27171
CTC159
DEAD SET -BLOWS F4001
CHECK/REPLACE CR4102,Q4401,R4001 AND T4401
RCA
F27171
CTC159
DISTORTED AUDIO, OSD INDICATES STEREO IN BOTH MONO AND STEREO MODES
CHECK/REPLACE CR1703 AND RE-ADJUST PILOT MONITOR
RCA
F27171
CTC159
LOW VOLUME LEVEL BUT AUDIO AND AUDIO CONTROL CIRCUIT APPEARS TO BE WORKING FINE
CHECK/REPLACE L1602
RCA
F27171
CTC159
DEAD SET - STAND-BY VOLTAGES ARE LOW
CHECK/REPLACE C4605 SHORTED
RCA
F27171
CTC159
INSUFFICIENT VERTICAL AND HORIZONTAL SWEEP AND APPEARS TO BE SENSITIVE NEAR REGULATOR CIRCUIT
CHECK/REPLACE R4117 FOR OPEN OR INTERMITTENT
RCA
F27171
CTC159
SIDES BOWED AT TOP OF RASTER - VIDEO AND AUDIO BOTH NORMAL
CHECK/REPLACE Q4804 FOR OPEN OR LEAKY
RCA
F27171
CTC159
BAD SIDE PINCUSHION - WIDE AT TOP AND BOTTOM AND PULLED IN ON THE SIDES.
CHECK/REPLACE CR4802 FOR SHORT TO GROUND
RCA
F27171
CTC159
RCA
F27171
CTC159
DEAD SET-BLOWS AC LINE FUSE
CHECK/REPLACE Q4401,SCR4101,CR4102 AND T4401
RCA
F27171
CTC159
BLANK RASTER, NO VIDEO, NO AUDIO OR TUNER OPERATION
CHECK/REPLACE CR4118 FOR OPEN
RCA
F27171
CTC159
HORZ. OUTPUT SHORTS AFTER 30 SECONDS TO 1 MINUTE
CHECK/REPLACE C4303
RCA
F27171
CTC159
POWER LED STAYS ON - NO VIDEO OR AUDIO BUT DOES HAVE HIGH VOLTAGE.
CHECK/REPLACE C3319 FOR LEAKAGE
RCA
F27171
CTC159
SET PULSES ON/OFF WITH HIGH PITCHED SQUEAL AND PICTURE COMES UP WITH FOLDOVER
CHECK/REPLACE CR4104 (33v ZENER)
RCA
F27171
CTC159
EXCESSIVE HORZ. WIDTH - WIDTH CONTROL INOPERATIVE
RCA
F27171
CTC159
BRIGHT SCREEN WITH RETRACE LINES - NO VIDEO - UNABLE TO CONTROL BRIGHTNESS
CHECK/REPLACE Q2901 FOR SHORT (143806)
RCA
F27171
CTC159
PICTURE PULLS IN TOWARD CENTER FROM SIDES ONLY - CHATTERS INTERMITTENTLY
CHECK/REPLACE C805
RCA
F27171
CTC159
RCA
F27171
CTC159
NO VIDEO BUT OSD OK - VERT COMPRESSED AT TOP
CHECK/REPLACE C4502
RCA
F27171
CTC159
VERTICAL COLLAPSED AND PULLED IN ON THE SIDE 3 INCHES
CHECK/REPLACE CR4501 - MAY CHECK GOOD OUT OF CIRCUIT
RCA
F27171
CTC159
PICTURE DIMS OR NO LUMINANCE
CHECK/REPLACE R2717
RCA
F27171
CTC159
WILL ONLY TURN ON INTERMITTENTLY - CYCLES ON/OFF WHEN NOT WORKING.
CHECK TO SEE IF LEADS ON L4101 AND R4113 ARE TOUCHING
RCA
F27171
CTC159
NO VIDEO
CHECK/REPLACE R1435
RCA
F27171
CTC159
OSD MISSING BUT VIDEO IS NORMAL
CHECK/REPLACE CR4404 FOR LEAKAGE
RCA
F27171
CTC159
CHECK/REPLACE C805
RCA
F27171
CTC159
VIDEO MISSING AND DARK SCREEN - OSD AND AUDIO WERE OK
CHECK/REPLACE R4409
RCA
F27171
CTC159
POOR TINT RANGE BUT SET HAS GOOD GREY SCALE
CHECK/REPLACE U1001
RCA
F27171
CTC159
NO VERTICAL SWEEP OR INTERMITTENT VERTICAL SWEEP
CHECK/REPLACE Q4502 FOR LEAKY
RCA
F27171
CTC159
PICTURE VERY DIM
CHECK/REPLACE C3132
RCA
F27171
CTC159
RCA
F27171
CTC159
SET PULSATES ON AND OFF
CHECK/REPLACE CR4160 FOR LEAKY
RCA
F27171
CTC159
PULSATES ON AND OFF
CHECK/RESOLDER CONNECTIONS ON PIN 12 OF T4401
RCA
F27171
CTC159
CHECK/REPLACE R2717
RCA
F27171
CTC159
VERY DIM PICTURE
RCA
F27171
CTC159
NO VERTICAL SWEEP - MAY BE INTERMITTENT
CHECK/REPLACE CR4501 (ECG125)
RCA
F27171
CTC159
CHECK/REPLACE R2717
RCA
F27171
CTC159
PICTURE VERY DIM
CHECK/REPLACE C3132
RCA
F27171
CTC159
NO SOUND
CHECK/RESOLDER OPEN GROUND TRACE TO U1900 IC (PIN 14) - CHECK ESPECIALLY ALONG LEFT HAND SIDE OF PC BOARD
RCA
F27171
CTC159
CHECK/REPLACE R2717
RCA
F27171
CTC159
NO VERTICAL SWEEP
CHECK/REPLACE U4501,R4506 AND C4502
RCA
F27171
CTC159
RCA
F27171
CTC159
NO VERTICAL SWEEP
CHECK/REPLACE U1001
RCA
F27171
CTC159
RCA
F27171
CTC159
CHECK/REPLACE C4303
RCA
F27171
CTC159
NO START UP AT NORMAL LINE VOLTAGE - SET WOULD START AT 80-90 VOLTS
CHECK/REPLACE CR4165 (MAY BE THERMALLY SENSITIVE)
RCA
F27171
CTC159
Q1902 AND Q1903 (AUDIO OUTPUTS) ARE RUNNING HOT
CHECK/REPLACE R1909 AND R1910 FOR CHANGE IN VALUE
RCA
F27171
CTC159
BAND SWITCHING INOPERATIVE (STAYING IN MID BAND ON ALL CHANNELS)
CHECK/REPLACE C3605 SHORTED ON 33v LINE
RCA
F27171
CTC159
RCA
F27171
CTC159
NO SOUND
CHECK/REPLACE C1211 FOR SHORT
RCA
F27172
CTC159
VERY DIM PICTURE
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
CHECK/REPLACE C805
RCA
F27172
CTC159
CHECK/REPLACE Q4103
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
NO HORIZONTAL SYNC
RCA
F27172
CTC159
RCA
F27172
CTC159
CHECK/REPLACE R4109
RCA
F27172
CTC159
CHECK/REPLACE C4303
RCA
F27172
CTC159
CHECK/REPLACE R2717
RCA
F27172
CTC159
RCA
F27172
CTC159
CHECK/REPLACE L1602
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
CHECK/REPLACE R2717
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
PICTURE VERY DIM
CHECK/REPLACE C3132
RCA
F27172
CTC159
RCA
F27172
CTC159
CHECK/REPLACE C4303
RCA
F27172
CTC159
RCA
F27172
CTC159
CHECK/REPLACE C4502
RCA
F27172
CTC159
RCA
F27172
CTC159
CHECK/REPLACE R2717
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
PICTURE VERY DIM
CHECK/REPLACE C3132
RCA
F27172
CTC159
RCA
F27172
CTC159
CHECK/REPLACE U1001
RCA
F27172
CTC159
PULSATES ON AND OFF
RCA
F27172
CTC159
NO SOUND
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
NO VIDEO
CHECK/REPLACE R1435
RCA
F27172
CTC159
NO SOUND
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
DEAD SET
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
RETRACE LINES
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
NO VERTICAL SWEEP
RCA
F27172
CTC159
RCA
F27172
CTC159
RCA
F27172
CTC159
NO VERTICAL SWEEP
CHECK/REPLACE U1001
RCA
F27172
CTC159
RCA
F27172
CTC159
CHECK/REPLACE C805
RCA
F27172
CTC159
CHECK/REPLACE R4409
RCA
F27172
CTC159
RCA
F27172
CTC159
NO VIDEO
CHECK/REPLACE R1435
RCA
F27185DW
CTC159
CHECK/REPLACE R2717
RCA
F31220
CTC159
RCA
F31220
CTC159
PICTURE VERY DIM
CHECK/REPLACE C3132
RCA
F31220
CTC159
RCA
F31220
CTC159
RCA
F31220
CTC159
RCA
F31220
CTC159
CHECK/REPLACE Q4103
RCA
F31220
CTC159
NO SOUND
CHECK/R
