RCA 27F530T M134C
ntehicks
PostPosted: Wed Mar 25, 2009 3:14 pm    Post subject: RCA 27F530T M134C Reply with quote
27" TruFlat RCA Model 27F530T Chassis M134C
Getting a strange look on the screen when I turn the set on.
the bottom half of the screen looks normal the top half has very thin trace lines and the center of the screen has a very bright line across it. In the center of the screen I can make out the channel and mono which are displayed backwards and inverted.
I have tested all caps and replaced the one in the vert area. I have replaced the IC301 Vert amp. and tested several resistors.
I just wanted to see if someone else has worked on an issue like this and found the problem section.
Thanks.
Nate
curt wolfe
PostPosted: Thu Mar 26, 2009 5:45 pm    Post subject: Reply with quote
Sounds like open d301, if not change c302. D301 common on the vertical problem, may check ok, just replace.
ntehicks
PostPosted: Thu Mar 26, 2009 11:26 pm    Post subject: Repaired !!! Reply with quote
Thank you. You were right D301 was the bad apple I replaced that tonight and all is working now.
