rca 32" model# 32V434T fixed
Wendell1980
PostPosted: Fri Aug 01, 2008 10:04 am    Post subject: rca 32" model# 32V434T fixed Reply with quote
i replaced the flyback and horiz transistor and set still does not power up led still flashes
PostPosted: Fri Aug 01, 2008 11:19 pm    Post subject: Reply with quote
Confirm soldering on drive transformer (T401)
Confirm 130V supply. You can measure it at pin 2 of the IHVT (flyback).
Confirm continuity between pins 1 and 2 of flyback.
Wendell1980
PostPosted: Tue Aug 12, 2008 10:02 am    Post subject: Reply with quote
fixed thanks
tru_shard
PostPosted: Thu Mar 19, 2009 7:02 pm    Post subject: please explain Reply with quote
Could you please tell me all that must be done to fix the problem with this model?
Wendell1980
PostPosted: Sat Mar 21, 2009 4:46 pm    Post subject: Reply with quote
if its dead and led flashes 3 times replace flyback and horiz transistor
tru_shard
PostPosted: Sun Mar 22, 2009 10:55 am    Post subject: thanks Reply with quote
Thank you all for your replies...I will order the parts soon and finally fix this hunk of junk
