RCA CTC117C No start up (dead)
_Carl
PostPosted: Sun Sep 20, 2009 6:15 am    Post subject: RCA CTC117C No start up (dead) Reply with quote
Hello everybody. I am working on a RCA CTC117C with no start up (dead). Fuse good, diodes good, horizontal op good, scr checks good. I have 150 Volts on pin 1 HV transformer, voltage to the scr and voltage on the collector of horizontal OP. Anyone give me some help on this. TIA
_Conti
PostPosted: Sun Sep 20, 2009 6:16 am    Post subject: Reply with quote
Carl, Time Machine. Check R668 in the Mtt001A.
If OK Check for bad solder in that Board.
_Conti
Carl, I also found this on my old Tips that may help.
Check C672 (220 uf 25v) may be open of dry. This can cause the 16v standby to be low about 7 volts instead of the Normal 16v.
