RCA CTC187CN3
Robert
PostPosted: Fri Jun 01, 2007 10:25 pm    Post subject: RCA CTC187CN3 Reply with quote
Does anyone have a good source to find a replacement for T4101 RCA 221948?
Diode CR4106 was shorted and the degauss thermistor was off its leads. Both
were replaced but the 5Amp fuse still blows the second power is applied.
Pins 3&5 show short in the circuit. Any suggestions for further checks are
also appreciated.
ERic
PostPosted: Fri Jun 01, 2007 10:26 pm    Post subject: Reply with quote
Hi Robert did you replace the STK730-030 when you replaced that
CR4106 diode..I would say the U4101 is shot and it took out the diode
You must replace them together or it will happen again..Do you have the
schematic..Eric
Terry
Eric's right Robert, I had the same problem with a CTC187 chassis and it was
the STK730-030 that was not showing a short until hit by the B+.
Terry
Peggs
C4105 will cause this mess all over again if not replaced........
Peggs
alexmotta
PostPosted: Fri Jan 30, 2009 5:24 am    Post subject: GE 35GT695 with a CTC187CN3 chassis - manual needed Reply with quote
I am sorry to intrude in your topic, but I am about to retire a GE 35GT695 with a CTC187CN3 chassis because I don't have the circuit schematics. Would someone have it? Or would someone know where I can get it? Thanks!
