Sircas
Posted: Fri Apr 16, 2010 4:26 pm Post subject: RCA D52130 CTC211A Chassis will Not come On |
My RCA D52130 CTC211A Chassis will not come on! It just makes a clicking sound and the On button green led lights up momentarily. The same when using TV button or remote.
I have researched on riddledtv.com
NOT FOR SURE WHICH APPLIES
1.)
D52130-JX1 A CTC211A Horizontal No start-up Replaced T14751
2.)
D52130-JX1 A CTC211A System Control No start-up Resoldered open R13141
Where can I find a schematic for this model/Chassis TV to Replace T14751 or resolder open R13141?
Any and all help would be appreciated!
Thanks, |
Posted: Sat Apr 17, 2010 4:05 pm Post subject: |
Those aren't guaranteed to fix your tv but those are markings you'll find on the circuit board itself.
Sircas
Posted: Sat May 15, 2010 4:45 pm Post subject: RCA D52130 CTC211A Chassis Marking or Diagram! |
What marking are you referring to? Can you specify? I did not get the marking or diagram. |
Posted: Sat May 15, 2010 9:34 pm Post subject: |
T14751 and R13141 are the markings you should look for silkscreened onto the circuit board. |
Sircas
Posted: Mon May 17, 2010 5:34 pm Post subject: |
What would be causing the TV to actually not come on most of the time? I actually got it to come on 3 times in the past month. However, I must leave it on all day.
Is this a solder break or replacement item needed?
Thanks for all your help! |
Posted: Tue May 18, 2010 7:31 am Post subject: |
Sircas wrote: | Is this a solder break or replacement item needed? |
Yes, I'd start with the components we already specified. |
