RCA D52W15BYX1 Ch# ITC222 need power def board   Goto page 1, 2  Next
Eric_
PostPosted: Sun Jul 20, 2008 1:55 pm    Post subject: RCA D52W15BYX1 Ch# ITC222 need power def board Reply with quote
Hi this board has a hole burnt in the board. I need to buy a board for
it. I need the board# to make sure I get the right part.
Thanks for any help.
Terry_
PostPosted: Sun Jul 20, 2008 1:56 pm    Post subject: Reply with quote
Eric, which board is it? the main board with the flyback on it?
Eric_
Hi Terry thats the one I need as I put in 2 HOT transisters and they
shorted out so I think the flyback is bad now
The customer kept using it when it was cutting out like they all do..I
think my best bet is to get the complete deflection board..Eric
Terry_
PostPosted: Sun Jul 20, 2008 1:57 pm    Post subject: Reply with quote
Eric, I don't see a part named deflection board just a component parts list.
There is a flyback for those chassis but usually I find that the splitter
and flyback seem to go bad together. The flyback isn't very expensive but
you need to get the original part # from the old flyback. There are several
flybacks for that chassis. There is also a point on that chassis that gets a
bad connection and can cause a burn-through but you can hard wire it. it is
under the board near the flyback area. If my memory serves me well the fly
is only twenty some dollars plus shipping from Global believe it or not.
Jim_
Hi,check the bad caps near the front of the board.They are green in color.I
think their locations are cp 150,cp140 and cp110 and cp120.good luck,Jim
Peggs_
PostPosted: Sun Jul 20, 2008 1:58 pm    Post subject: Reply with quote
there should be a label with some numbers on it........
I have a couple of junked-out 222's.....
Eric_
Hi Peggs here are the #on the board bar code#PSB 850 another #right by
the bar code#264114
Thanks for looking..Eric
PostPosted: Sun Jul 20, 2008 2:00 pm    Post subject: Reply with quote
I have a brand new never been used power
supply / deflection board for the ITC222
chassis......has the flyback on it.......
The part number on the box is # 264102
Brand spanking new.......right from RCA.......
The box has been collecting dust for about 3 years
now........in June 2005 it listed for $230......dealer
cost $198......
If this is the part you need make me an offer......
it is in perfect condition.....all you would need to do
is clip off the anode cup from the flyback.......they always
came with a flyback that had the cup on it.......so it would
also work in the direct view sets......
Right now my parts web site is down so I cant tell
what part number you need.......but I will sell this to you
if you need part number # 264102......
frharrell
PostPosted: Wed Feb 16, 2011 12:45 pm    Post subject: Reply with quote
Did you find a source to buy this board (or get old repaired) I have an RCA 52" TV wiht same issue adn need a 264102 power board
murfy888
PostPosted: Fri Mar 04, 2011 1:37 am    Post subject: Reply with quote
If you can have access to any junk shops or repair shop I think you can find anything the same with your defective appliance. The same with mine computer monitor. Bought a defective LCD monitor and swap good parts to repair my defective monitor.
Goto page 1, 2  Next
Page 1 of 2
