theroundhousernr
Posted: Mon Oct 15, 2012 6:04 pm Post subject: RCA F32649 throughs sparks |
I have a RCA ,model number F32649
I noticed the screen was flashing with a arching sound coming from it. I pulled the back cover off and plugged it in.
The screen and focus assembly produces a blue spark across the assembly at the same time the screen flashes. Whats going on???
How can this be fixed?
Thanks |
theroundhousernr
Posted: Mon Oct 15, 2012 6:46 pm Post subject: |
Just did some research and the part making sparks is the flyback transformer. |
Posted: Mon Oct 15, 2012 9:43 pm Post subject: |
"Change" the flyback transformer. |
theroundhousernr
Posted: Thu Oct 18, 2012 9:51 am Post subject: |
Just as an update. I sanded the flyback transformer to remove the carbon and cleaned with alchohol. I then used clear silcone and patched the pin sized hole . I applied it thick and over a large area. The tv now works .
My question is how long will a fix like this last? I have located a flyback transformer and will most likely order this as a back up. Anyone done this before and know how long this will last?
Thanks |
Posted: Thu Oct 18, 2012 2:18 pm Post subject: |
4evr & evr (or until the residence burns down). |
theroundhousernr
Posted: Thu Oct 18, 2012 8:33 pm Post subject: |
WOW i really didnt need to hear that. I didnt think silicon was flamable. Are you suggesting that this isnt safe? |
theroundhousernr
Posted: Thu Oct 18, 2012 8:37 pm Post subject: |
As i understand it silicon won't burn until around 1000 degrees and is used on circuit boards all the time. |
Posted: Fri Oct 19, 2012 12:22 am Post subject: |
Let's just say .... I wouldn't let the set play unattended.  |
