RCA GE Proscan Guest
Posted: Thu Jul 19, 2007 5:49 am Post subject: RCA GE Proscan Service Menu Codes - TV |
* Turn the TV off.
* Press simultaneously the {MENU} {VOL -} {CH -} buttons for about 8-10 seconds.
* The TV will turn on with the Service Menu displayed.
* Press the {POWER} button to exit. |
Posted: Thu Jul 19, 2007 5:49 am Post subject: Service Menu Code |
* Turn the TV off.
* Press and hold the {VOL -} & {CH -} buttons on the TV.
* Release both buttons when the green power light comes on.
Posted: Thu Jul 19, 2007 5:50 am Post subject: Service Menu Code |
To enter service mode, push and hold the {MENU} button on the set.
While holding, press and release the {POWER} button,
then press and release the {VOL +} button.
You will now have some information on the screen: "P0 V0"
To actually be able to change these values, you must push {VOL +} on the remote so the information reads V76. Then pushing on the Channel +/- will change the "P" value.
P1 - 3 are error codes. If there is a problem with the set that can be self-diagnosed, the "V" will report the code. These codes are available in the RCA repair manual.
P4 - 7 control the horizontal size, shift, vertical size and shift. |
Posted: Sat Jul 21, 2007 2:06 am Post subject: Service Menu Key Sequence |
On the front panel (FPA) of the F38310, simultaneously and quickly press the {CH -} & {DIRECTV} buttons. If successful, you should have displayed on the bottom of the screen:
Version Number: XX.XX P:0 V:0
(Note: Modifications to the parameters and values can be performed using the remote at this point. The remote must be in “TV†mode. To be sure, cover the IR bulb on the remote and depress the {TV} button, then you can use the remote for adjustments.)
Before adjustments can be performed, you must enter the password code to enable the FPA (or remote) for access. Use the {VOL +) button to change V:0 to V:76. Once this is done, you can now change the parameter setting for the desired function.
Be sure to write down the V: settings PRIOR to making changes in the event you need to revert. |
Disclaimer:
Privacy Policy
Advertise on RiddedTV.com
