RCA HD56W58YX1
_Mark
PostPosted: Fri Nov 07, 2008 12:17 pm    Post subject: RCA HD56W58YX1 Reply with quote
Got new call for RCA model#HD56W58YX1.Customer say that unit shuts itself off came back on and shut down again.Any ideas what can be the problem.And please if somebody have schematic send it my way.
Thanks in advance.
_eric
PostPosted: Fri Nov 07, 2008 12:17 pm    Post subject: Reply with quote
That's an ATC321B and the manual with DLP training is here. The schematics
are labeled numerically, if you wish to label them differently by all means do
so.
http://www.mediafire.com/?jizmexwimcz
_mark
PostPosted: Fri Nov 07, 2008 12:18 pm    Post subject: Reply with quote
Thanks a lot Eric for all schematics this is real help.Sincerely Mark.
_Jim
Hi,i just fixed one like that with the same problem. I found 4 swollen caps
on the power supply board .The board is on the left side from the back .It was not too difficult to remove .There are notches in the board that you line up ,then lift it out of the plastic tray.Good luck ,Jim
