_Alvin Guest
Posted: Thu Feb 26, 2009 12:04 pm Post subject: RCA L37WD22YX5 PLASMA TV |
Hi Guys
We have a Rca plasma tv model L37WD22YX5 for
repairs..screen is lit but no picture or sound The
screen displays "NO USABLE SIGNAL"
channel number and info comes up on screen..
anyone have an idea of what the problem may be..is it the
signal processor board..Anyone have a PDF of the
service manual for this set..Any help would be appreciated.
Alvin |
_bill Guest
Posted: Thu Feb 26, 2009 12:04 pm Post subject: |
replace open fuse IC33 on PCB BOARD.
The fuse is about 2" behind the tuner. You will have to jump in a new pico
fuse. |
_Alvin Guest
Posted: Thu Feb 26, 2009 12:05 pm Post subject: |
Hi Bill
Thanks for the prompt reply
On the circuit board about 2 inches to the rear of the
tuner I see a small device with a F on it..Is this the pico
fuse and what is it's current rating.
Alvin |
_John Guest
Alvin, Replace the 500Ma with a 750 or 800 Ma. The rca p/n for the 750 ma is 275819. I use an ICPN20 which is 800ma. |
_Alvin Guest
Hi John
I have some 750 ma pico fuses in stock so
I will install it with pigtails..
thanks for the reply..your help is appreciated.
Alvin |
ahya12
Posted: Thu Nov 08, 2012 5:25 pm Post subject: |
_Alvin wrote: | Hi John
Alvin |
Hello, I am in Calgary, Canada and have the same issues with my TV. Can you tell me if http://www.digikey.com/ has the part you are talking about so that I can fix my unit or let me know another place that I might try?
Thanks guys,
Al |
