RCA L42WD22YX6 turns off after turning on
ht
PostPosted: Sat Jul 26, 2014 4:26 am    Post subject: RCA L42WD22YX6 turns off after turning on Reply with quote
First I would like to thank the responsible party for exceping me as a member.
My TV turns off after its pluged in. I took the back off and there are two green leds that light up when you plug it in. After a couple of seconds one goes out then shortly after the other goes out. When the second led goes out on the back of the screen (inside tne case backside of screen has flat metal panel with little holes in it) you can see a flash of light at that same time throught these holes. Thats about all I know. Any one ???
curtis wolfe
PostPosted: Sat Jul 26, 2014 6:01 pm    Post subject: Reply with quote
Check the 1000mfd caps in power supply for doomed/puffed on top
ht
PostPosted: Sun Jul 27, 2014 3:58 pm    Post subject: RCA L42WD22YX6 turns off after turning on Reply with quote
Thanks Curtis
You were dead on. I got perfect TV now.
Thanks again
