RCA LED52B45RQ Wont Power On
Samseim
PostPosted: Thu Jan 18, 2018 10:45 am    Post subject: RCA LED52B45RQ Wont Power On Reply with quote
Model: LED52B45RQ
So i aquired this tv in a non working condition and the apparent problem is that when the power button is pressed, the tv does not turn on. When the power button is pressed the red LED will blink off and then back on. Ive used a flashlight to test to see if the backlight has gone out, but i still cannot make out an image. Suspecting the main board I replaced it however that did not solve the problem. All the pins going from the power board to the main board appear to be fine when tested with a multimeter. However where things appear to go wrong is when I test the leads for the LEDs on the power board. When the power button is pressed the voltage jumps to 70V then it immediately starts to taper off taking about a minute to reach 0V. Which is obviously a problem.
So long story short I'm not sure what to try next on this thing. If more information is needed just let me know!
https://imgur.com/a/oNHPL
PostPosted: Thu Jan 18, 2018 1:42 pm    Post subject: Reply with quote
I'd go with LEDs.
Could have been EEPROM, but you already replaced the Main board.
