ffejry4ever
Posted: Thu Jun 22, 2017 11:53 am Post subject: RCA LED55G55R120Q - No HDMI signal |
Received this 55" TV from my neighbor who said if I can fix it - it's mine.
Note: I do not have the remote, unfortunately. So I am unable to use the factory reset mode to see if my problem is fixed - it requires the arrow keys on the remote to confirm.
Anyway.
Issue: Both HDMI ports - it says "no signal". I have tried all 3 of my Chromecasts and Kindle Fire Sticks. So my initial thought was the board might be an issue.
THEN - the HD antenna works just fine. The component cables work just fine as well. It is only the HDMI ports.
I have looked into the back panel and everything seems fine. There are a couple plugs that do not have anything plugged into. I do not see a loose wire or anything like that during my brief examination.
The picture below shows the board with everything except red circles plugged in.
https://ibb.co/mQvO3Q |
Posted: Thu Jun 22, 2017 12:56 pm Post subject: |
Main board is likely. |
ffejry4ever
Posted: Thu Jun 22, 2017 1:34 pm Post subject: |
What makes you think main board? Is the main board the same thing as the part I showed in the picture? |
Posted: Thu Jun 22, 2017 2:20 pm Post subject: |
Part Type: Main Unit, Main Board, HDMI Input, A/V Board, Signal Board, Tuner Board, USB Input, Digital Audio Coaxial
EEPROM, Microprocessor, HDMI and other inputs are handled by this board. |
ffejry4ever
Posted: Thu Jun 22, 2017 3:46 pm Post subject: |
Think it's worth the 40-60 bucks to get a new board? Currently, my father has a 50" Toshiba Plasma TV. I am sure this TV is much, much better.
I can only use component cables on this TV due to the lack of HDMI working.
Not sure what to do about the Fire Stick, which he uses. The HDMI to component converters themselves are already $40 to begin with. |
Posted: Thu Jun 22, 2017 4:24 pm Post subject: |
Not my money.
If you decide to try board be SURE that numbers match. Visit ShopJimmy. All I had was your sets model number and obtaining 'correct' board requires more than that. |
