RCA M134c locked out on front buttons.
Badboy111
PostPosted: Mon Mar 24, 2014 7:16 pm    Post subject: RCA M134c locked out on front buttons. Reply with quote
RCA TV 27V412T front buttons are locked.
RCA 27" TV
Model 27V412T
Cassis M134c
Do not know how to unlock front buttons.
Can you help please.
PostPosted: Mon Mar 24, 2014 7:50 pm    Post subject: Reply with quote
Child Lock allows you to lock the buttons onthe front of the TV.Press MENU to see the main menu.Press CH+ or CH- to highlightPreferences.Press OK to enter the Preferencessubmenu.Press CH+ or CH- to highlight FPA(Front Panel) Lock.Press VOL+ or VOL- to turn on or offFPA Lock. Choose On to disable all thebuttons on the front of the TV. FPA LockOn will appear on the TV screen eachtime you press buttons on the front ofthe TV. You can still operate the TV withthe remote control. You can still use thePOWER button on the front of the TV, butonly to turn off the TV (not on). Set FPALock to Off to cancel this feature so youcan use the buttons on the front of the TVagain.Press MENU repeatedly to exit themenu or the menu will automaticallydisappear within a few seconds if nobuttons are pressed on the remotecontrol.
http://www.manualslib.com/products/Rca-27v412t-328368.html
Badboy111
PostPosted: Tue Mar 25, 2014 10:15 am    Post subject: Reply with quote
I thank you for your reply but I do not have the remote.
PostPosted: Tue Mar 25, 2014 5:52 pm    Post subject: Reply with quote
Oh well.
A GE/RCA/universal remote with 'MENU,' 'Channel up/down,' 'Volume up/down,' and 'OK' (Enter, etc.) buttons.
OR
Go to Google search box;
Punch in Brand & Model number along with the word 'remote.'
Sort through results. Both the exact 'original' (new & used) and any 'replacements' (new - may look different than original, but should still work same features) should be available at various prices.
Badboy111
PostPosted: Wed Mar 26, 2014 7:29 am    Post subject: Reply with quote
Thank you for your help.
