mark9971
Joined: 11 Jan 2010 Posts: 5 Location: Houlton, Maine
Posted: Mon Jan 11, 2010 10:44 am Post subject: RCA M50wh72s ATC332A, repair shop couldn't fix it? |
I took my set into to get worked on and it came back with vertical lines. This was not even the original problem. It was shutting off on me. I replaced the light and it did not fix the problem. Now it has these lines and yes it is shutting off again. The repair place said that this was out of their range of expertise. I have found that if I leave a fan running beside it the set will stay on now if I could only fix the lines! Any help would be much appreciated.
Posted: Mon Jan 11, 2010 11:38 am Post subject: |
is this an ATC351 chassis? |
mark9971
Posted: Mon Jan 11, 2010 6:52 pm Post subject: |
The Chassi # ATC332A |
mark9971
Posted: Tue Jan 12, 2010 11:27 pm Post subject: |
Has anyone out there seen this problem? If so do you know how to fix it. |
Posted: Wed Jan 13, 2010 11:54 am Post subject: |
If the vertical lines were not there when you took the set in for repair it is logical to assume that the problem is a result of that servicing.
Look for a loose LVDS cable, loose or incorrectly installed grounds, loose or incorrect lead dress, etc etc. If you do not know, or are not comfortable with this information. Take the set to a qualified servicer. (warranty authorized servicer).
If you are going to open the set up be forwarned. Make sure that the set is unplugged before you do anything. Do not measure the lamp with a meter while set is on. (your meter will be destroyed and you will have a very bad day).
The shutdown after warm is most likely a poor ventilation problem (plugged up filters) or a power supply problem.
Hope this helps.
mark9971
Posted: Wed Jan 13, 2010 7:05 pm Post subject: |
My major problem is that I live in a small town in Northern Maine and I can not find a qualified servicer. I already paid the other guy almost 350.00 for him to talk to a technician on the phone and try to fix my TV. He replaced the light that cost me 130.00 and replaced two fans that cost me around 100.00 and a board that cost me 150.00. When I picked it up it was not shutting off but had these new lines. He told me that at this point he was beyond his expertise. Oh and in less than a week it was shutting off again. At this point I am thinking it would be more cost effective to just buy a new tv. I am really not sure what i would be looking for to fix a loose connection and I dont want to do something that is going to make it not work at all. Any suggestions would be welcome. |
Posted: Thu Jan 14, 2010 7:53 am Post subject: |
sounds like you were robbed. you probably already knew that though. |
Posted: Thu Jan 14, 2010 2:17 pm Post subject: |
Was the person's name Gus? |
mark9971
Posted: Fri Jan 15, 2010 11:35 pm Post subject: |
no not named Gus. So is there any quick way to fix these lines? Does anyone know anyone in the Northern Maine area that I can take this set to or should I just live with the lines at this point and start saving for a new set? If so what is a good set to buy that is going to last me a while and not break after three years. Should I get a rear projection set again or go fo LCD? |
Posted: Sat Jan 16, 2010 12:46 pm Post subject: |
There are none. Average warranty states 1 year, and you're lucky to get that.  |
