RCA P61960 PTK195Y06T voltage regulator model
pani
PostPosted: Wed Sep 28, 2011 7:35 am    Post subject: RCA P61960 PTK195Y06T voltage regulator model Reply with quote
Hi,
I have an RCA rear projection TV Model P61960 Chassis PTK195Y06T.
The voltage regulator transistor on the heatsink in the low voltage power supply is burned and I want to buy a new one but I can't read the number on it . The only thing I can read on it is ST and something like DOK242 but cannot read the rest. I don't have a schematic and don't know where to find one. Can someone help me with the model number of this transistor ?
Thx in advance.
PostPosted: Wed Sep 28, 2011 8:34 am    Post subject: Reply with quote
Location number of transistor? (should be on board close to heat sink).
? IF Q14101 (Q4101) RCA 237469 Just a guess - and there are probably a few other parts in same area bad.
pani
PostPosted: Wed Sep 28, 2011 11:58 am    Post subject: Reply with quote
You are right ! The number on the sink is Q4101. Thanks a lot for your help.
pani
PostPosted: Thu Sep 29, 2011 9:07 pm    Post subject: resistors Reply with quote
Hi,
You were right! There are two resistors right in front of the transistor I cannot read the colors. Can you help me with them one is R124 and the other is R125. And one other question is, can you tell me where I can download a schematic for this set?
Thx Question
PostPosted: Thu Sep 29, 2011 9:55 pm    Post subject: Reply with quote
http://elektrotanya.com/
Most likely will have "similar" if requested by chassis number.
R14124 .27 ohm 2 watt
R14125 100 ohm
pani
PostPosted: Fri Sep 30, 2011 6:03 am    Post subject: Reply with quote
Thanks a lot !
