RCA projo D52W19 strident squeal after 20 minutes from fly
PostPosted: Tue Sep 22, 2009 11:00 am    Post subject: RCA projo D52W19 strident squeal after 20 minutes from fly Reply with quote
This been in shop for a while , I have repair it , but the flyback was sqealing after some time .
So I decide to change the flyback.
But the new part is doing the same ....
It is a very high pitch sound.
If I push the fly , it stops , or it change the pitch.
If I try to flex the main board , it stops or change frequency too.
Pushing on the anode lead does the same (stops or change frequency of squeal)
I don't know what's the problem , everything is well soldered , and well fixed/attached.
Any ideas ??
Want to tell you that when I received the new fly , there was not any wires attached to the new fly , had to pull the old ones to put on the new one , and .... the anode is not real tight in the housing. Don't know if related , but is was doing the same in the old fly and anode lead was fixed tight in it.
_Larry
PostPosted: Tue Sep 22, 2009 11:01 am    Post subject: Reply with quote
seems i had that problem replaced flyback didnt fix it, there is a coil with
the magnet on top net to fly. something with no metal and press on it.
should stop. then silicon it.
Paul
If it's doing it (squealing) reliably, I'd try to find it w/a sniffer. They
sell electronic ones that will do the job, but I've got an old stethoscope
that I pulled the piece off the end so it's just an open hose and it works
great ! I just move it over and around components and it's VERY good at
isolating exactly where the squeal is coming from. That's assuming it is a
coil or something small. If it's the flyback or a transformer, the squeal
usally eminates all around it and it'll be loud all around it. Before I got
the stethoscope I'd put a short piece of hose in one ear and plug the other
one and that worked just as good.
_Bill
PostPosted: Tue Sep 22, 2009 11:02 am    Post subject: Reply with quote
Its either LL037 or LL029. Usually the 37
