RCA PTK195Y06T no video
pani
PostPosted: Sun Jul 24, 2011 3:32 pm    Post subject: RCA PTK195Y06T no video Reply with quote
Hi,
RCA rear projection TV RCA 61960
Chassis PTK195Y06T
For some days the screen had like black drops on the left side and some times also on the right side. But the last time I turned it on after some seconds the screen did close from the bottom to top. It was like a black curtain slowly going up and now I only have audio and no video. I have tested the HOT off board with an analogue meter and it is ok.
hope you can help me soon solving this problem.
slinteriors
PostPosted: Mon Jul 25, 2011 11:44 am    Post subject: Reply with quote
I would check the vertical output to see if the CRts are in shutdown due to loss of vertical as thats a safety feature that prevents the CRTs from being damaged when vertical deflection is lost.
pani
PostPosted: Mon Jul 25, 2011 1:35 pm    Post subject: Reply with quote
Were is the vertical deflection circuit located is it behind the flyback transformer?
slinteriors
PostPosted: Mon Jul 25, 2011 1:46 pm    Post subject: Reply with quote
Its all the way up on the front right corner of that board attached to a heat sink its location number is U14501.
pani
PostPosted: Mon Jul 25, 2011 2:28 pm    Post subject: Reply with quote
Ok . I will find it when Im home. And I will measure the capacitors and let you know.
pani
PostPosted: Mon Jul 25, 2011 2:30 pm    Post subject: Reply with quote
Do you know if there is somewhere I can download a schematic of this tv?
PostPosted: Tue Jul 26, 2011 11:17 pm    Post subject: Reply with quote
elektrotanya.com
Try searching by "basic" chassis number.
