Jrat
Posted: Sun Jun 21, 2009 1:48 pm Post subject: RCA R52WM24 ITC222 Dead Set / 3 Strikes - Information wanted |
I picked this up a couple weeks back, being told it had a convergence problem, but powered up fine. Unfortunately, it doesn't.
No visually bad caps. Fuses are all good. HV seems to come up just fine. I've gone through everything I could find online for common fixes, troubleshooting, and whatnot; including reflowing the flyback and HOT. I haven't yet reflowed the small signal board connectors, but will be getting to that today.
I don't have, or have access to a Chipper Check, so I went ahead and dumped the contents of the eeproms manually through direct serial connection/soldering to the eeprom pins. I'm after the error codes stored in there. My first question is, is there a listing of where the codes are stored within or any info on how they are stored? Something like the INIT directory files that come packed with chipper - which list the hex locations/values for individual tv settings.
I'd also like to know if anyone could be bothered, if possible, to send me over some other eeprom dumps from this chassis, so that I can compare and check for possible corruption.
Last thing, does anyone have schematics for this set? I hate to be a beggar, but I just don't have $40 to fork over for the service cd.
Thanks tons for any help anyone may have for me. |
Jrat
Posted: Sun Jun 21, 2009 8:40 pm Post subject: |
I reflowed the small signal board connectors as suggested by some folks, which made no difference.
Push power, HV kicks on after a moment, I hear the speakers power up. A second or two later I can hear the crackling of the CRTs. A couple seconds pass, and the cycle repeats.
One of the eeprom images does appear that it may be corrupt, after viewing in a hex editor. It just doesn't look typical of any binary/hex I've seen previously; but I'm surely no expert. I dumped each eeprom multiple times to help ensure accurate data.
Another two eeprom images appear to contain identical information. I found five eeprom ICs total. |
Disclaimer:
Privacy Policy
Advertise on RiddedTV.com
