RCA TV/DVD Combo BD20TF10 - DVD player won't close
Rose
PostPosted: Sun Apr 19, 2009 5:20 pm    Post subject: RCA TV/DVD Combo BD20TF10 - DVD player won't close Reply with quote
Good Evening, I have a RCA TV/DVD Combo BD20TF10 with a problem. My youngest child put a quarter into the DVD player which caused a jam. I very carefully pulled out the quarter, but now the DVD player will not close. It does try to close when the TV is on, but cannot as though something is blocking it. I have looked into the DVD player and do not see anything in the way that looks obvious.
Any advice as to how to close the DVD player would be appreciated. Playback would be great, but is not a priority at this point.
Thank you,
Rose
PostPosted: Tue Apr 21, 2009 5:50 am    Post subject: Reply with quote
I would open it up and manually retract the DVD tray all the way. there should be a gear inside that you can rotate all the way until it is closed.
Rose
PostPosted: Tue Apr 21, 2009 3:58 pm    Post subject: Reply with quote
By opening it up, I will assume you mean to take the TV case off of the TV which then exposes the inside. Once I do that, is there a way to extract the DVD player?
Thank you for your reply!
