REPAIRED Sony KP-57WS500 convergence problem intermitten.
ntehicks
PostPosted: Sun May 16, 2010 9:25 pm    Post subject: REPAIRED Sony KP-57WS500 convergence problem intermitten. Reply with quote
I turn on the Tv and the picture looks great. once the Tv has warmed up then alll of a sudden the picture looks 3-D and the colors are off. the picture looks bowed in as well. I was wondering if this means that the convergence chips are going bad or where I would start. thanks so much for your help.
PostPosted: Sun May 16, 2010 11:20 pm    Post subject: Reply with quote
Replace both STK392-560 IC's, PS5001 5 Amp Pico Fuse and C5018 1000ufd 35 Volt.
ntehicks
PostPosted: Mon May 17, 2010 11:45 am    Post subject: Reply with quote
Ok I have order the parts. but I have a question. I see some places charge over $40.00 each for the STK392-560 and other places charge $5.99 each. they both offer a 6 month warranty on the part. should I purchase the cheaper one?
PostPosted: Mon May 17, 2010 1:12 pm    Post subject: Reply with quote
As long as the site is reputable and sells 'original brand name' (Sanyo, for example) parts, you should be OK.
Although I've personally never had a customer come back who had opted for 'el cheapo,' you hear all sorts of horror stories about using them.
ntehicks
PostPosted: Mon May 17, 2010 10:03 pm    Post subject: Reply with quote
I have pulled PS5001 and tested and it is testing good. I have pulled c5018 and tested with tester and it is testing good. is it possible that it is just the two STK chips.
PostPosted: Tue May 18, 2010 4:21 am    Post subject: Reply with quote
Yes.
ntehicks
PostPosted: Thu May 20, 2010 11:23 am    Post subject: Reply with quote
I went ahead and replaced C5018 35v 1000ufd and replaced Both STK392-560. I was sure to clean off the heat sink and re apply a good amount of heatsink compound. tested TV for 2 hours and not a problem. Thanks again for all of your Help.
