Samsung CS-29Z50 CRT TV on Standby after Service Menu Change
ezee
PostPosted: Tue Dec 22, 2009 3:52 am    Post subject: Samsung CS-29Z50 CRT TV on Standby after Service Menu Change Reply with quote
Hi,
I have Samsung CS-29Z50 (29 in CRT Slim TV) and due to curverd corners I tried to set using service menu (info -> menu -> mute -> power). While setting I accidently pressed INFO button again and it auto changed some G2-Adjustment values. I switched off the TV.
From after that TV is not turning on, its on standby mode and when I press power button or service menu button I only can hear the click but again no picture comes and it goes to standby again.
Please suggest I can t do the master reset as I am not able to enter to service menu again.
Any idea?
PostPosted: Tue Dec 22, 2009 7:02 am    Post subject: Reply with quote
Live and learn...next time at least read the whole procedure so you'll know which button(s) NOT to hit, accidentally or otherwise!
ezee
PostPosted: Tue Dec 22, 2009 7:32 am    Post subject: Reply with quote
Any solution to that ... I feel that firmware is got currupted or incorrect G2 values.... but the question is how to correct that?
Do they have any external reset as well?
