Samsung DLP HL s5086W - Lamp blown after 2 hours of use
lorikirby
PostPosted: Fri Feb 24, 2017 8:43 am    Post subject: Samsung DLP HL s5086W - Lamp blown after 2 hours of use Reply with quote
I just replaced lamp and ballast on my Samsung DLP tv (2006). I was very careful to use gloves and didnt touch the lamp bulb at all. Reset lamp timer, everything was working wonderful. Watched tv approximately 2hrs last night, turned on this morning within 15min there was a loud pop and the screen went black again. What would cause the lamp bulb to pop Question
PostPosted: Fri Feb 24, 2017 8:52 am    Post subject: Reply with quote
Where'd you get your bulb?
lorikirby
PostPosted: Fri Feb 24, 2017 8:56 am    Post subject: Reply with quote
I purchased it online thru walmart.com. i believe the manufacturer was Mwave.
PostPosted: Fri Feb 24, 2017 9:06 am    Post subject: Reply with quote
I'd probably get in touch with the seller and ask about a warranty replacement.
Also make sure any fans are operable.
lorikirby
PostPosted: Fri Feb 24, 2017 9:20 am    Post subject: Reply with quote
What is the process to check the fans?
lorikirby
PostPosted: Fri Feb 24, 2017 9:29 am    Post subject: Reply with quote
I noticed when i tried to turn on, the tv emmets high pitched peeps. But i believe i can both fans running on either side od unit.
