samsung hcm4216wx has sound but no picture
jasonc
PostPosted: Thu Sep 04, 2008 8:15 am    Post subject: samsung hcm4216wx has sound but no picture Reply with quote
samsung 42" projection tv
model HCM4216WX
The problem started with the tv picture taking 5 minutes to come on, then 10 minutes, then 15...eventually taking 30 minutes to get a picture. Now it has sound but no picture at all no matter how long it's on. I took the cover off and there are no obvious problems. I have a good multimeter and electrical experience (mostly automotive).
Any help would be greatly appreciated
Thanks,
Jason
PostPosted: Thu Sep 04, 2008 9:34 am    Post subject: Reply with quote
Unplug connector GT404 (Screen) on the sub pcb (This is the board that has the HV transformer on it. This transformer has a big red wire coming out of the top of it.) GT404 will be close to the transformer.
If set powers on after unplugging this connector, you will have to purchase a new red crt pcb and make a modification to the sub pcb.
jasonc
PostPosted: Thu Sep 04, 2008 4:21 pm    Post subject: Reply with quote
I want to clarify. The tv allways powered up and had sound but slowly lost picture.Now there is no picture. I found gt404 and disconnected wire (pink). There was no change. what should the voltage be at gt404? Any other Ideas? what to check next?
Thanks,
jason
PostPosted: Fri Sep 05, 2008 11:22 am    Post subject: Reply with quote
Please be carefull, the DC level can be anywhere between 150 VDC and 800 VDC depending on current draw.
I apparently had a brain cramp and missed that you still had sound.
You need to do a visual check of IC301 vertical Ic for signs of heating. look at CRT boards for signs of overheating resistors. Check connector CNZ03 pins 1 & 4 for + and - 20 VDC. Do a visual for burnt resistors around convergence chips. (two large heat sinks side by side)
Hope this helps.
Note: Going hunting for moose with 12 year old granddaughter all of next week. (I live in Alaska)
jasonc
PostPosted: Sun Sep 21, 2008 8:16 am    Post subject: Reply with quote
I have 22.86v on the + and 1.566v on the - of cnz03. little fuse (10A)in the - circuit is blown. What would cause this fuse to blow?
PostPosted: Thu Sep 25, 2008 11:25 am    Post subject: Reply with quote
You most likely have bad convergence IC's. The fuse opens as a direct result of too much current being drawn by the convergence IC's. Replace them as a pair and do a careful visual of the low value 1 watt resistors in and around the convergence IC's. When the IC's go bad, many times there is a resistor or two that burn up due to the excessive current.
Hope this helps.
jasonc
PostPosted: Sat Sep 27, 2008 12:12 pm    Post subject: Reply with quote
I found the bad little fuse and a bad ic diode. I could not find the parts for it so I bought a remanufactured power/deflection board. problem solved.
Thanks for your help!
Jason
