SAMSUNG - HL61A750A1FXZA - green tint
epicfailguy
PostPosted: Sun Jun 11, 2017 6:45 pm    Post subject: SAMSUNG - HL61A750A1FXZA - green tint Reply with quote
I recently graduated with an Associates in electronics, and my friend gave me this massive tv and said "If you can fix it you can have it". All that is wrong with it seems to be the screen is tinted green tint.
So far I have tested to make sure all inputs have this problem, they do. Then i attempted adjusting the settings on it no help. I also checked to see if there was any magnetic interference by trying the tv in different places around the house.
I've done a little bit of research online, which i will continue, but the only things I am able to find are all things that suggest hiring a technician to fix, I would like to fix this myself if possible, and any help would be greatly appreciated.
epicfailguy
PostPosted: Fri Jun 30, 2017 5:48 pm    Post subject: Reply with quote
can anyone halp?
PostPosted: Fri Jun 30, 2017 6:59 pm    Post subject: Reply with quote
Are we SURE about the whole Model Number?
Are Menus affected or normal? You may want to reference User Manual.
Are all three LED light engine sources lit?
Customer settings? or Service Menu settings?
Any "TIMER ... LED ... STAND BY/TEMP" LEDs lit or flashing on the front panel?
epicfailguy
PostPosted: Sat Jul 01, 2017 6:34 pm    Post subject: Reply with quote
I double checked the model number, it was wrong, and I fixed the title.
The Menus are are affected, and I do not have the manual but i will look online for one, I feel a bit silly not having thought of that.
I dont know what light engine sources are or how how to get into the service menu settings. Also no LEDS are on or flashing on the outside of the TV, I have not opened the TV yet to look inside because I don't know where to start or what to look for. :/
PostPosted: Sat Jul 01, 2017 8:31 pm    Post subject: Reply with quote
Model STILL incorrect.
(Your search - HL61A7501AFXZA - did not match any documents.)
You won't be able to see light engine or source LEDs until TV is partially disassembled.
I'd hold off on Service adjustments until obvious causes are ruled out.
epicfailguy
PostPosted: Mon Jul 03, 2017 3:31 pm    Post subject: Reply with quote
alright as soon as I have a day off work ill take her apart.
https://ibb.co/knVdfF
thats a picture of the model number since i apparently cant type it and look at it at the same time Razz. Also thanks for the info you've given me so far I appreciate it!
PostPosted: Tue Jul 04, 2017 9:40 pm    Post subject: Reply with quote
HL61A750A1fxza
