Samsung HLN 617W ballast
farshad behbahani
PostPosted: Thu Apr 15, 2010 4:22 pm    Post subject: Samsung HLN 617W ballast Reply with quote
HEllo,
What is the difference between the ballast :
BP47000016A and Bp47000003A, both are being sold as parts for the H617W
Thank you for your help
Confused Confused
PostPosted: Fri Apr 16, 2010 5:00 pm    Post subject: Reply with quote
This unit was made using four different lamp's.. smile!!
Confirm on the lamp door which one you have.
Toshiba = 100W White sticker
Phillips = 100W Red Sticker
Phillips = 120W Orange Sticker
Osram = 120W Green Sticker
The lamp and ballast must match or you will have short lamp life.
Clear as mud??? Laughing Laughing
farshad behbahani
PostPosted: Sat Apr 17, 2010 1:07 pm    Post subject: Samsung HLN 617 W Ballast Reply with quote
Thanks Jesse,
It is the Red sticker, Phillips 100W. The problem I have is that after we replaced the lamp about less than a year ago PN# BP96-00224J (Samasung replacement) we recently lost the picture.
You turn on after being off for a while and you get color picture for a short while ( 1- 2 minutes). THen there is noise on the picture and whitin a minute you loose the picture completely (Screen is balnk but audio available).
You then get then Turn on/off tones and the three led's cycle mentioned in the forum.
I am assuming its the ballast since it gets the next most wear and tear after the lamp.
regards
Farshad [img][/img]
